Undo while editing a sketch
gianmario_scottigianmario_scotti Member Posts: 22 EDU
I am editing a fairly complex sketch (not a part, yet), and as far as I can tell, there is no history tracking. How do I undo my last action, while working on a sketch and not a part?
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    edited June 2020
    Ctrl+z and Ctrl+y are shortcuts for Undo and Redo. Also, these button are available in the toolbar
    Keep in mind undo history isn't forever. You can only undo/redo actions from the current session. If you close your document and open it again, the undo/redo buttons will be grayed out. However, the Versions and History button will still show previous changes and let's you activate an older version of your part studio.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,004 image
    Every sketch "commit" (pressing green checkmark button) is stored in history. Also, it's good practice to keep your sketches simple.
