Problem with extrude
in Drawings
Hi,
Remove tool, does not allow to select curved faces, have you a solution to select them?
J'ai voulu joindre 2 surfaces décalées (outil loft), je pensais coudre les 2 surfaces décalées et la jointure pour après faire un enlèvement de matière, mais 'outil coudre (boolean) ne fonctionne pas.
J'ai essayais de faire l'enlèvement de matière (outil extrude) mais celui ci ne sélectionne pas les faces courbes.
Comment faire?
NeilCooke Moderator, Onshape Employees Posts: 5,868
Thicken should do it, or you can create a Plane over the part, sketch the profile and extrude up to face.Senior Director, Technical Services, EMEA5
Could extrude be edited to allow curved face selection? (Because curved faces can be extruded in FS)
@dominique_chaligne
I agree, it is impossible to select it currently. What I was suggesting is that they could allow it to select a curved face.
