Can't find M8 screws in the standard content in the assembly
ella_meunierella_meunier Member Posts: 5 EDU
Hi,
I can't find M8 or M6 screws in the standard content in the assembly.
Whatever option I choose I only see M16 and larger screws.
Is it just not existing or do I something wrong
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    Can you send a screenshot of what you are seeing? Everybody uses the same content database so it's not possible for it to be different (or at least it shouldn't be).
  • ella_meunierella_meunier Member Posts: 5 EDU
    Here's the screenshot.
    All I get is a dropdown with those sizes ...
    Change Komponente - do you need that grade of bolt? Try the Grade C one above it.
    That does the trick...
    THX a lot, Neil
