Helix Length
leo_donaldson531
Member Posts: 2 EDU
I have a cylindrical hole which I have put a helix on, however the hole is longer than I want the helix to be, and the helix just carries to the end of the cylinder. I was wondering if there was a way to make it stop at a certain depth down the tube?
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
When creating the helix, use the "height and turns", "height and pitch", or "turns and pitch" options instead of the "turns" or "pitch" options. You'll be prompted to select a circular edge instead of a cylindrical surface. The helix will start at that edge and have the same diameter. But the height/pitch/turns can then be entered manually.6
