Scale in Drawing
ehsan_pazooki
Member Posts: 52 ✭
Hello Guys,
Could some one please tell me, How can I check and change the scale of my drawing?
I right-click on the "part 1" in the menu, then click on "create drawing of part 1" and after all in want to check and change the scale of drawing.
But I don't know how.
Best regards and thank you
Ehsan
john_mcclary
Member, Developers Posts: 4,004 PRO
You can double click your view in your drawing. Or right click the view and find view properties.
In there you will see scale.
If you see 1:1 (sheet) for example. That means the view is the same as the sheet and will always update to match the sheet (which is preferred)
To change sheet scale, right click the white area of the drawing and change sheet properties5
