3D connexion problems with Onshape?
Does anyone have a definitive answer to solve the 3D connexion issues with Onshape? My devices only work intermittently which is super frustrating because it will start out working and then stop. I think the problem is happening when I open a second browser or start changing between different parts/documents.
https://www.3dconnexion.com/service/drivers.html
Onshape, Inc.
Onshape, Inc.
Would I have to run that 3DxNLServer every time? I've seen this happen a few times a day. Sometime the device stops working within a few minutes of opening a document.
I couldn't find @Nuno.
Just this morning, my navigator was working fine. I had multiple browser tabs open (Chrome) and then I open this additional tab via clicking on the email link and the next thing I know the navigator stops working. I stop the driver and start it up again and the properties show it's in Chrome not Onshape again and not working.
I've logged a ticket with 3D connexion. Has anyone else logged a ticket?
) suggested I use the Spotlight Search to find 3dxNLServer. once found just hit enter, which restarts it. After that just shift+refresh Onshape and it almost always works again. Not ideal, but it's become pretty habitual for me to hit Command+space (for spotlight) -> 3dx (autocompletes to 3dxNLServer) -> Return -> shift+refresh. Takes like 2 seconds. I realize this has been described above, but it's worked for me. let me know if this works for you
I had my ticket answered from 3D Connexion. For me the solutions are to shift-refresh the browser (Chrome) tab.
Then if that doesn't work, I have to close the browser, hit the start menu (windows 10 64 bit), go to the 3D Connexion tools and stop the driver, wait 10 seconds, Start the driver and then open the browser again. The second process was the recommended action from 3D Connexion.
Since 3D Connexion's last couple of driver updates it been a lot better. Most times shift-refresh works. So make sure you're on the latest driver too.
Open Windows Defender Firewall and select the first option "Allow one app...".
Add two .exe files, 3DxSmartUi.exe and 3DxService.exe, from the following directory (each file must be selected in turn from the path):
C:\Program Files\3Dconnexion\3DxWare\3DxWinCoreAdd the exceptions for all networks (domain, private and public).
Reboot
