OpFillet for creating corners
All,
Can we use opFillet to create corner between two intersecting curves(both on same plane)?
I am aware that sketch is an option but i don't want to use it as sketch cannot adapt changes in intersecting curves. Please share your views. Thanks.
  • lanalana Onshape Employees Posts: 761 image
    opFillet will not work on curves. You can extrude these curves as a surface (opExtrude would handle that) and use opFillet to fillet the 2-sided edge between them. Then extract the boundary chain to get filleted curve corner.
  • Kirankumar_ThimmegowdaKirankumar_Thimmegowda Member Posts: 28 PRO
    Thanks lana for the reply. It works.
