Is possible to define component transparency and associate it to a Display State?
Mr_GK
Member Posts: 19 ✭✭
Hi,
I created this engine model bellow
https://cad.onshape.com/documents/87b92e0d2e75f7888c1abdd2/w/5164382dabb149ba4a9d40af/e/d3b1057e648448b66858b5ff
It has an animation defined at Main assembly and its document's tab
But some components are inside some others. I created a Display State and turned off some items.
Is possible to define some transparency to components and link it to a display state? I coudn't do it by myself.
Please, comment my model as well.
john_mcclary
Member, Developers Posts: 4,015 PRO
I can't test it where i'm at but if you make a part transparent in an assembly Nd create a display state, and it DOESN'T sawe, then the answer is no for display states,. But the aswer is yes if you use configurations in the assembly and partstudio instead5
