How to fix unwanted extrude when adding surface text feature script
Hi,
Im using the FS Surface text:
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/c8e6602fb08acac97a10a38e
and it works perfect! Almost...
Whatever I try within my knowledge. I get extra unwanted extrudes....
Does anyone no how to fix this?
Or perhaps try to remove material instead of "raised add".
extrude 25mm-1mm:
When creating new part (Raised add). I can select and remove the opposite part:
When not adding, but removing (that is also a option for us). The FS is also acting weird and cutting on the otherside.....
I think I have to try the surface options....
That works perfect!
