Drive UI focus with other UI parameters?
EvanReese
Member, Mentor Posts: 2,695 PRO
I'm trying to improve the usability of the Selection Fillet feature I just released. Rather than a wall of text explaining it, I made a 40-second video showing what I'm looking for.
For the click-averse reader, the short version is I'd like the UI to focus on the "faces" query box, when I pick the "faces" enum. As of now, it stays in whatever query param is already active, which will also now be hidden in the UI.
You can play around with the transform feature to see what I mean outside array parameters. Would fixing that address this issue?
In my particular case, I think it would, but even Transform has some UI that I find a bit confusing. Another 40-second video of that.
