Limit UP_TO_NEXT to the merge scope?
EvanReese
Member, Mentor Posts: 2,967 PRO
Is it possible to use opExtrude with an UP_TO_NEXT end condition that doesn't reference everything in the context? I'd like to limit it to my merge scope (or a queried set of bodies I choose).
NeilCooke
Moderator, Onshape Employees Posts: 6,056
Would UP_TO_BODY work?Senior Director, Technical Services, EMEA5
Any idea how to get that working? I'd love to avoid adding another query field.
I considered copying/booleaning bodies, but, aside from being expensive, if the user has already added part clearances, they wouldn't boolean anyway. I guess I could just add the full set of end conditions like the standard extrude, but I'm trying to make the feature UI minimal (and so far, you can see I'm failing at that
