Improvements to Onshape - July 15th, 2020
cody_armstrong
cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 228 image
edited July 2020 in New in Onshape
 It's July already, and we are here again with another update! This update includes a highly-requested new feature as well as several improvements in different areas of Onshape. Let's get started.
CATEGORIES
You can now manage your properties with Categories in Onshape Professional and Enterprise. This new functionality allows you to efficiently display properties depending on the category they belong to.
https://onshape.wistia.com/medias/5oej4iz8mr
FLIP NORMAL WHEN CREATING PLANES
You can now flip the normal direction of a construction plane.
https://onshape.wistia.com/medias/nodt2gzz82
DRAFT IMPROVEMENTS
Implied and Explicit Mate Connectors can now be used as the reference for a Neutral plane when creating draft.
https://onshape.wistia.com/medias/phqsh52kiz
APPEARANCE IMPROVEMENTS
You can now assign appearances to features in a Part Studio. This simplifies the process of applying appearances and allows them to update parametrically with the features.
https://onshape.wistia.com/medias/oavkucf851
MEASURE IMPROVEMENTS
You will see new icons for Measure and Mass Properties at all times in the bottom right corner of a Part Studio or Assembly.
https://onshape.wistia.com/medias/6dk548hsk6
ENTERPRISE IMPROVEMENTS
You will find two new permissions dashboards when viewing analytics in Onshape Enterprise. These were created to give you better insight into how data is being shared in your company.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • bo_pollett
    bo_pollett Member, csevp Posts: 2 PRO
    Flip Normal on planes has been a long time coming. Thank you! Thank you!  <3
  • bruce_williams
    bruce_williams Member, Developers Posts: 842 EDU
    very nice group of improvements!  All of them are very useful right away.
    www.accuratepattern.com
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    Very nice. Appearance by feature will be very much used!
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    Categories looks promising :) I was hoping to be able to filter all those unused fields :)
    Feature Color: excellent!
    Flip Plane Normal: sweet! this will come in handy when tracing reference images
    I like how the new measure window is a pop-out like the mass properties window.
    This will be nice, I used to need to select a solid body to open the mass properties tool, when checking a bunch of individual masses. It's nice to be able to open it up before hand in those situations.
  • john_mcclary
     just need to be able to get the weight property to populate on drawings, this is a very tedious task at the moment!
    agreed, əven with featurescript
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    Nice work! looking forward to trying these new features.
  • rafael_gomez_sjoberg
    rafael_gomez_sjoberg Member Posts: 4 PRO
    Great new features, especially the feature color and the flip plane normal. Thank you!!!
  • danny_payne
    danny_payne Member, User Group Leader Posts: 42 ✭✭✭
    Great features. I really like how new improvements are always coming out and are so improving the program. Thank you.
  • emagdalenaC2i
    emagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
    Categories are great!!
    Nice work
    Un saludo,
  • muhammed_bilgi
    muhammed_bilgi Member Posts: 1 ✭
    Thank you! Please add next a mirroring feature in assemblys.
  • Ivan_Deetlefs
    Ivan_Deetlefs Member Posts: 23 ✭✭
    I've been picking up bugs since new release. Most concerning, however, is that my autofields aren't updating. I have triple checked that reference data is correct and selected correctly when referenced. Anyone had this same problem?
  • john_mcclary
    What do you mean autofields?
  • Theo_R
    Theo_R Member Posts: 82 PRO
    "Categories looks promising"
    Agreed. I look forward to seeing how these can tie into other aspects of filters and PN.
  • emagdalenaC2i
    En este enlace podéis ver las Novedades de Onshape en español
    https://youtu.be/aqSnmRcJo0w
    Un saludo,
  • alex_pitt472
    alex_pitt472 Member Posts: 6 ✭✭
    Nice improvements! Thank you!
  • Cache_River_Mill
    Cache_River_Mill Member Posts: 225 PRO
    I flippin' love Onshape :) Y'all's updates are always so immediately helpful (sometimes I didn't even know I wanted these features!)
    Thank you Onshape team! These are great!
  • ladislav_pochop
    ladislav_pochop Member, HON-TS, pcbaevp Posts: 10 PRO
    Nice, thank you :) very appreciate possibility to assign appearances to features 👍
  • brucebartlett
    Love the measurement update. The drag out feature is great for screenshots
  • kevin_elliott
    kevin_elliott Member Posts: 8 PRO
    Love the add appearance to features, but I would also like to be able to Add Appearance to a face/part in an assembly with the appearance only applying to that assembly. In this way I can have standard parts colour coded within the assembly for their different uses (ports, etc).
  • brucebartlett
    Yes, I also want this. That way I can simulate painting of an assembly and not have to drive it from the part studio.
  • Theo_R
    This would be helpful to me for preparing renderings. I would use assembly appearance settings for export to .gltf for rendering without the tedious process of edit in context or open linked document.
  • brucebartlett
    edited July 2020
    Theo, you can use the BOM to change appearance, just add the appearance column click, this may help you. This works great until your parts have been released or changed to rev, then I 'd like to be overridden at the assembly level.
  • fnxf
    fnxf Member, User Group Leader Posts: 147 PRO
    Do you need the parts actually mirrored, or just inserted a second time? I have used linear pattern when I needed an assembly (or parts) a second time.
  • john_mcclary
    A mirror is different than a pattern. It implies the part is also opposite in shape. This is something that has been requested in assemblies for a while. But comming up with a clever way to do it in Onshape would be interesting to see
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,100 image
    Not always. They may be the same parts assembled on the other side but rotated 180 degrees. SolidWorks does a good job but still falls short in many ways.
  • fnxf
    I've just had this case recently. and used assembly circular pattern to much success. If I really need mirrored parts I make them in the part studio.
  • john_mcclary
    Typically I would also use a circular patter for this, mostly because of the lack of mirror, and lack of mirror options (as @NeilCooke pointed out) SW gives you 4 options per part in your mirror. But that usually ends up as a over complicated mess. Just recently I tried to mirror in assembly in SW and it was still missing a rotation/mirror option for 2 of the 8 parts. So it was a half and half solution there as well. Hopefully Onshape makes this a clean and simple solution.
    But I don't see it happening until you can have two way communication with an assembly without using in-context. Right now we only have a one way street.
