transformBox3D help
EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
I'm trying to find a bounding box of a part, that is oriented in a certain direction, but I'm not getting the results I expected from transformBox3d. Any pointers?
Here's the code I'm using
FeatureScript 1311;
import(path : "onshape/std/geometry.fs", version : "1311.0");
annotation { "Feature Type Name" : "embedded" }
export const embedded = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Printer Z-direction", "Filter" : BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
            definition.printercSys is Query;
            annotation { "Name" : "nut", "Filter" : EntityType.BODY && BodyType.SOLID}
            definition.nut is Query;
        var nut = definition.nut;
        var printercSys = evMateConnector(context, {
                "mateConnector" : definition.printercSys
        debug(context, printercSys);
        var nutBox = evBox3d(context, {
                "topology" : nut,
                "tight" : true,
                "cSys" : printercSys
        debug(context, nutBox);
        nutBox = transformBox3d(nutBox, toWorld(printercSys));
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    I'm not actually sure of the use case of transformBox3d in its current form.
  • EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
    @NeilCooke
    thanks! I need to study the different options for debug. I only ever use the most basic one 😅.
    I will eventually need to reference the "top" face of the box (relative to my cSys) to create a sketch there, so I need a box at the actual location. This assumes there's not a better way to get a plane touching a part at the farthest point along a direction.
    For the curious, I'm exploring whether I'm able to automate the creation of support parts for embedding nuts in 3D prints similar to what's in this article: https://markforged.com/blog/embedding-nuts-3d-printing/, and that's meant to be part of a larger Nut Pocket feature. I've wanted to try writing my own version with all of my dream functionality since I saw the cool one that @owen_sparks worked on.
    @NeilCooke
    I still couldn't figure out how to transform a box there, but in my particular case, I found a better way not using a box3D. Since my "nut" body always has a vertex (or a few) at the farthest point (unlike a sphere, or something where part of a curved face is the farthest portion), I did it this way, and it's working:
            var nutPoints = qOwnedByBody(nut, EntityType.VERTEX);
            var farthestPoint = evaluateQuery(context, qFarthestAlong(nutPoints, printercSys.zAxis))[0];
            var supportPlaneOrigin = evVertexPoint(context, {
                    "vertex" : farthestPoint
            var supportPlane = plane(supportPlaneOrigin, printercSys.zAxis, printercSys.xAxis);
