Grow/increase a dimension in a pattern?
 doug_smith714
                    Member Posts: 6 ✭
doug_smith714
                    Member Posts: 6 ✭
            I want to create a circular pattern of a rectangular extrusion feature.  As the feature rotates, I want the length of the rectangle to increase. Is this possible? I've tried a sketch pattern where the length is an equation (1+#rotangle/300) and the starting angle of the rectangle is defined by the dimension #rotangle, but this did not work.
thanks
             romeograham
                            Member, csevp Posts: 719 PRO
                    @NeilCooke romeograham
                    @NeilCooke
 Has a great resource for this.
 See this post for info and links: https://forum.onshape.com/discussion/comment/32380#Comment_323805
