Hole Feature Improvements
I'd like to see some improvements to the Hole Feature. As I have seen mentioned elsewhere it would be nice to expand the types of holes you can create with it (different threads and sizes) I think it could be combined with the new standard parts library so you can just select the bolt type you want to use and voila youre all set.
Additonally I would like more placement options. Currently you have to use a sketch point, more precisely you have to use a sketch point on the plane from which your hole begins. I would like to see the option to select a sketch point on any plane, then have a secondary selection to define the start plane and direction of the hole.
4
