Feature Request - Variable linking in string properties
anthony_tatum458
Member Posts: 3 ✭
in General
It would be awesome if, when entering data into a string based property field, you could reference Configuration and/or Feature variables present.
For example, as shown in the image below, I have the part properties, Width, Height, Name.
For the Name field, I would like to name it: "Nut, Hex, #Width x #Height, 1-72"
and have it read: "Nut, Hex, 1 in. x 1 in., 1-72"
Is this a possibility or does the feature already exist in some form that I am simply unaware of?
Thanks!
Thanks!
Here is how I populate the BOM with stocksize and featurescript (big thanks to @MBartlett21 for most of the code)
