Defining constants to be referenced instead of typing a value in a bunch of places
duncan_thomas
Member Posts: 9 ✭✭
Hi
Hoping there's a quick answer to this. I'm coming from OpenSCAD, and one feature I can't find in onshape is the ability to give some value a name (e.g. 'LEVEL_THICKNESS = 10') and use this instead of a numerical value when setting up dimensions, extrusion lengths etc. I found this very handy in the past, and I miss it here. I can sort of do it using constraints by arbitrarily picking one edge to be the 'master' edge, but I'd rather just have it in a list I can edit somewhere, rather than trying to remember which I picked as master.
It would also be handy to be able to do simple math, like '2*LEVEL_THICKNESS' or 'LEVEL_THICKNESS + MIN_GAP', although that is solvable using multiple shapes and constraining them to be next to each other.
Loving the videos and looking forward to finding time to experiment more.
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
You're talking about parametric dimensions. This is not implemented yet, but it is highly requested feature and you can find plenty of discussions around. Use ?-menu and give Onshape feedback so they will add you to the request and you will be informed when it's implemented.
//rami5
