How do you delete old action items that were never completed and no longer are relevant?
William_SchlundWilliam_Schlund Member, Channel partner Posts: 9 ✭✭
I have some old action items. Thye were not completed and the parts have long since gone away...
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    I also came across this anomaly recently. We are working on a solution to fix it. For now, you’ll just have to ignore them. Sorry!
  • NikNYCNikNYC Member Posts: 68 ✭✭
    This issue is complicated by how irrelevant old baggage is highlighted orange but so too are crucial sketches that happen to have lost at least one reference but otherwise are perfectly fine for your actual parametric progression. So you can't manually delete orange stuff in general or you nuke your final result and you may not see it until a minute later when the final result updates.
    @nik_willmore - these are two separate issues. In the case of sketches, it is not a good idea to delete a sketch that is showing an error because there are likely to be some downstream features that rely on it. Edit and fix the error.
