A navigation 101 video to send to vendors and stakeholders
I made this video to send to people who don't know CAD along with an Onshape link.
One of the powerful features of Onshape is the ability to share the model via a view-only link with potential vendors and stakeholders for review without sending a copy of the CAD data, without them needing an account, without needing them to install anything.
This can:
What's your story of success or failure when sharing data with Onshape?
Is the video missing anything critical that your CAD reviewers will need to know?
This can:
- Cut down on confusion over which file is current.
- Remove the risk of a vendor misusing the data (selling it or producing it themselves). If you often get multiple quotes, most of the vendors you talk to won't be the one you pick, but they'll have your data.
- make it easier for non-CAD-users to review a design. For example someone in QC, or an investor, or just a friend you want to show off to.
Drawings are certainly trickier to make worth it, but again, exporting pdfs and moving them to an "RFQ" document at least prevents downloading and sharing of those pdfs, which could be a benefit early on in the RFQ process. You can at least skip the download/upload step by exporting pdf to a new tab then "Move to Document", but it's not much cleaner. This is just one more reason we need a better export tool that does batches with better ways to append/prepend the names.
As of now, it seems like the amount of work is about the same as just exporting and emailing (if not more), and the vendor's resistance to change is much higher, but I think a workflow like this has lots of benefits and will happen in the universe eventually. Onshape is the best positioned to do it and I'm rooting for 'em.
Simply create a new document and use the "derive" feature to drop in Part A and B in that document then share with manufacturer 1 and create another document for part B & C and and do the same and share that with manufacturer 2.
