Why can't I invoke section viewing while comparing versions?
StephenGStephenG Member Posts: 383 ✭✭✭
Did someone forget to add it?
Or is there a good reason for not allowing it that escapes me at the moment?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,028 PRO
    edited August 2020
    Compare is super limited... just saying
  • ChuckBergChuckBerg Member, csevp Posts: 7 PRO
    Need the section view in the compare function to evaluate wall thicknesses after changing dimensions.  This is critical for parts that have remaining material for post heat treatment grinding.
