Step 23 and 17 on exercise: Handle
ben_partouch
Member, csevp Posts: 160 PRO
Hi,
The Fill feature won't generate on step 23.
Also, in stage 17, I can only select edges as 1 object. Not 2 for each profile of the loft.
https://cad.onshape.com/documents/1ee94aa705a38f8456e5c85f/w/133cc81de2b0290eaed8b363/e/6580eae1176bc4a74f20aaf2
You can select 2 entities in one loft profile by expanding the dialog with the arrow. This might be why the Fill is not working either. See Step 15 on the Toothbrush exercise (the guide dialog), the same thing can be done for profiles.
