Post assembly machining
gerald_friedman
OS Professional Posts: 50 PRO
in General
Don’t know how common this is but I have an assembly to which I need to do post machining.
The only way I think I can do it is to make a configuration of the parts to be machined and play with the configuration images in the final drawings.
Anyone out there up against this issue?
In Solid Edge there is a special "assembly feature" for this purpose.
Depending on the complexity, it sounds like this might be one instance where you design multiple parts in the same part studio and use configurations to turn the "post-assembly features" ON or OFF. Alternatively, it sounds like in-context design may be useful here as well?
I've also seen someone using multiple branches to model a cast part before and after having additional features machined. He created the part in one branch. Then, made a new branch and added the machined features. If you need to change the pre-cast part, you can add features to the first branch and then merge them into the second branch. It seems at least analogous to your situation where you need to document the same part in two different stages of the manufacturing process. (You should even be able to show both states of the part on the same drawing if you link the drawing views to specific versions on each branch).
