Hi, How do I select the bottom inside edge to fillet on Exercise: Coffee Cup
MJCJ
Member Posts: 10 ✭
I am unable to select a bottom inside edge to fillet (slide 17/20) after using the revolve remove tools on this exercise. I know that it will be something that I have not done correctly but I have redrawn several time with the same result. I want to move on but want to resolve this.
https://cad.onshape.com/documents/eb7f563e622b07959e64300c/w/0785910482970f2f28e96aaf/e/39772bf552e05c448a84fde7
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Hi MJCJ,
Another option would be to use the `Select Other` command which will allow you to select through faces
https://cad.onshape.com/help/Content/select-other.htm
While you scroll through the other possible selections, they will highlight indicating what they are.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Looks like you fixed it?
