Is there a way to specify a material for a part to figure weight?
Member Posts: 235 ✭✭
Hello,
I was wondering if there is a way to set the material or density to calculate weight of a part/assembly?
  • Member Posts: 235 ✭✭
    Also, since I would use a STL to feed into 3D Printing software, perhaps the material (ABS, PLA, PC) would be embedded in the STL and drive an API run 3D Printer to select the material, or even a printer loaded with that material be chosen.
  • Member, Mentor Posts: 1,584 ✭✭✭✭✭
    Yep, bring on the day when the core of a part can be foamy 2024 aluminium alloy, transitioning seamlessly to a skin of solid monocrystalline titanium aluminide .... or mild steel foam core progressively firming up towards a high density D2 tool steel skin. Yay !
  • Member, csevp Posts: 31 PRO
    It would b great to be able to create some custom material specific gravity settings. Or enter in a specific gravity so that a weight can be calculated.
