How do I add vertices for a variable fillet?
ron_moreland
Member Posts: 90 ✭✭✭
I want to use variable fillet. The only vertices available to set fillet values are the end point of the fillet path. Can I add more point to the path?
Before Split
After Split
Hope this helps! Here is a link to the split feature documentation.
