Need help with mates and gear relation please
tarek_mustafatarek_mustafa Member Posts: 40 ✭✭
Hallo All, I learned a bit about gear design and created 2 gears with a gear ration of 2.5. I would like to do a visual test to see if I got the drawing based of my calculation right but I can't get the mates to work.
Please can someone help me to assign mates to the gears so I see them spin? A short step by step instructions would also be vert much appreciated!
I have made the document public.
Thank you!
  • navnav Member Posts: 258 ✭✭✭✭
    edited June 2015
    Nicolas Ariza V.
  • tarek_mustafatarek_mustafa Member Posts: 40 ✭✭
    Hi @nav , thanks for your reply. Yes I looked into the tutorial but unfortunately this didn't help me. If possible I don't like to model a support structure I just want to connect the two gears and see if they rotate correctly.
  • david_sohlstromdavid_sohlstrom Member, Mentor Posts: 159 ✭✭✭
    You need a hole in the center of each gear. Then you need a third part with 2 holes in it at the correct center distance for the gear pitch. Once you have that you mate 1 gear to each of the holes with a rotating mate. Next you go to the gear relation tool and choose the gear type. In your case spur gears. In the tool you set the gear ration and then you have it. This all has to be done in an assembly of course.
    If the gear teeth do not match up then you go in and rotate one of the mates so the gears mesh correctly.
    once all of this is done you can grab one of the gears and rotate it and the other gear will rotate at the correct ration. If you put a small hole out close to the teeth of each gear it makes it easier to see if your ratio is correct.
    Hope this helps
    Dave
    David Sohlstrom
    Ariel, WA
    Make revolute mates with respect to the origin.  Make two explicit mate connectors, one that is at the origin and one that is offset in one direction by (D1 + D2) / 2.  From here, make the revolutes with respect to those mate connectors.  Put the two revolutes in a gear mate with a ratio of 2.5 and start spinning them.
    For example:
    https://cad.onshape.com/documents/53bddf1068004057bd194191/w/7b9f3a41b660461c881d3b32/e/2c97adf316ce4ad2a88e6c01
    Jake Ramsley
    Hi @jakeramsley that is a Solution I was looking for but unfortunately I can not make it work using your description and example. I keep looking into this to figure it out. Thank you!
    Hi @david_sohlstrom thank you for your Solution. I am looking for something that @jakeramsley described and try now to make it work. Thank you!
    Excellent thank you all!
