How can I increase the width of the UISpec dialog box?
monroe_weber_shirk
Member Posts: 103 EDU
The UISpec dialog box is narrow and makes it difficult to read the values that we are entering with their units. Can I set the width of this box to a custom setting to make the dialog box easier to navigate?
EvanReese
Member, Mentor Posts: 2,868 PRO
Looks like a monstrously powerful feature. I don't think there's a way to change the width of the box though. I've usually ended up just favoring a UI that's longer vertically with groups as you have them. It's not the easiest to use, since for long ones you really need to just expand one group at a time. Now that I think of it, it could be useful to use editing logic to collapse other groups when you expand one. Not sure if that's possible either.5
