I am having assembly issue.
in General
I am a new user (one week) coming from Sketchup and have gone through all the initial self tutorials and I am having a basic problem with attachments in an assembly. I have a control arm successfully attached at one end, but when I attach the second end to its mating surface it attaches successfully but the first attachment snaps to the other end of the new mate.
The drawing is a shock absorbing structure on the nose gear strut of an aircraft called a "knee" spring assembly that attaches to an oleo strut. There is only one assembly tab, perhaps someone would be kind enough to look at it and tell me whats wrong.
https://cad.onshape.com/documents/d68f6239732b430d2573253e/w/59bf15a1cc74460ddde3c8a0/e/7160df705ce6bf657f07a454
Thank you in advance.
steve_shubin Member Posts: 1,111 ✭✭✭✭
@robert_lyons820
Theoretically, you would think that the revolute mate should work at all three pivot points. But when you try to do certain things using the revolute mate only, sometimes it just doesn’t work. There have been discussions about this elsewhere in this forum
.5
It’s a matter of degrees of freedom regarding the mates
So a cylindrical mate is less restrictive than a revolute mate. And a ball mate is less restrictive than a cylindrical made — at least I think that’s the proper amount of degrees of freedom of each mate
So for example — you can use a couple ball mates in place of a revolute made
The original document I posted was modified more than what is showing above now
