Exploded views
 gerald_friedman
                    OS Professional Posts: 50 ✭✭
gerald_friedman
                                  in Drawings
                    Is it true that when making an exploded view that any "subassembly" will have to be "grouped" to keep it from separating?
I think that's what I found unless I've done something wrong.
Principal Technical Services Engineer, Onshape
jjohnson@ptc.com
In the explode step dialog, if you select the assembly instance from the assembly tree (instead of a specific part instance from the graphics area) everything in the subassembly should move together. If that's not what you're seeing, please let us know!
Best,
Mike
