Exploded views
gerald_friedmangerald_friedman OS Professional Posts: 50 ✭✭
Is it true that when making an exploded view that any "subassembly" will have to be "grouped" to keep it from separating?
I think that's what I found unless I've done something wrong.
  • Jenny_JohnsonJenny_Johnson Member, Onshape Employees Posts: 11 image
    You can also choose the sub assembly in the instances list and move it that way
    Jenny E Johnson
    Principal Technical Services Engineer, Onshape
    jjohnson@ptc.com
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    @gerald_friedman
    In the explode step dialog, if you select the assembly instance from the assembly tree (instead of a specific part instance from the graphics area) everything in the subassembly should move together. If that's not what you're seeing, please let us know!
    Best,
    Mike
  • gerald_friedmangerald_friedman OS Professional Posts: 50 ✭✭
    Fantastic. Thanks all.
