Variable for quantity of pattern
james_howard360
Member Posts: 28 PRO
OnShape won't accept a variable to define the quantity in a linear pattern in a sketch. I think this is because the dimensions shows as "40x" instead of just "40", and I can't use letters to define the variable regardless of whether I define it as a number, length, or "any" category. Is there a way around this?
tim_hess427
Member Posts: 648 ✭✭✭✭
I believe this functionality just isn't supported for sketch patterns at the moment.
There is some discussion here: https://forum.onshape.com/discussion/comment/13517#Comment_135175
https://cad.onshape.com/documents/45a2c076f1c94dc89f7377af/w/cbcafb5dd5c0a80663e5df89/e/e05fc92da7da6c65b804da81
Perhaps your error is that the variable occurs below the sketch in history order?
www.virtualmold.com
www.virtualmold.com
