Sheet Metal Bookend Creation Help?
mark_leger
Member Posts: 10 PRO
Hi,
Trying to achieve a sheet metal model feature that can be boiled down to something like a bookend.
I've modeled a new bookend to experiment with, but I cannot get the middle tab to form properly.
I can't use a flange as it's 0 degree, and same for @MBartlett21 great Shaped Flange tool.
A sketch was created to then use the tab function, but while the Tab is not coming back with any errors, it's not formed either.
Here's a link to the document:
https://cad.onshape.com/documents/a0ed326b1a000dc74418e405/w/2c13dd39627b2b34ab3b461e/e/22cf18f3352a05182312ed4d
It could just be how I structured the creation of the part, but any help would be appreciated.
Thanks,
Mark
Thanks,
Mark
Would you be able to make the document public, so we can help you with it. At the moment, it is only shared via link.
I made a new part to show how I tried to used your Shaped Flanges, but as you can see, it will only connect to one edge rather than two.
@matthew_stacy I will have a look at your document when I have some time today, but glad to see it can be accomplished.
Thanks!
Twitter: @BryanLAGdesign
When you say "through the tangent of the radius," are you referring to the Right Face or Bottom Face tangent in your model? Maybe my issue is just using the wrong face for the removal sketch.
@matthew_stacy I was able to make the part using your procedure, but you're right, not the most elegant solution.
https://cad.onshape.com/documents/d0a486096e15d852a3e103ee/w/8298067f2b805c945a866122/e/38af666d68f820549bf08c53
I had used the inside face rather than the outside face for the cutout and now the tab is forming correctly.
@matthew_stacy I specified Bend relief type in the sheet metal model and it created the notches for me, referenced those in the sketch for the tab. Did not have to mirror anything.
Thanks again for your help guys.
@bryan_lagrange
@bryan_lagrange
It's part 3 in my shared model, and stems from the conversation @matthew_stacy started in the link above. You can sketch on the flat model!
It relates the cutout area to the tongue without variables and it accomplished in fewer steps.
Hi Mark — I’m happy to help with your model
https://cad.onshape.com/documents/fd91f8e4eaa5abaf393e7ada/w/d12929a9d309270a39a63012/e/b92593ca4f504d2f5eecfb26
