Changing existing drawing template from ISO to ANSI?
William_AitchisonWilliam_Aitchison Member Posts: 1
Is there a method for changing the standard of an existing drawing template?  I've only seen this option upon creation of a new drawing.
I need to change from 3rd angle to 1st angle projection for drawings going to a different region of the world.
Alternatively, is there a method for copying a title block to a new, blank 3rd angle drawing?  I cannot seem to copy entities between drawing tabs.
  • ben_smith434ben_smith434 Member Posts: 1 EDU
    I don't know if you have figured this out or not but try this:
  • cameron_miller456cameron_miller456 Member Posts: 3 ✭✭
    edited December 2021
    Same question as the title, I need to change a series of existing drawings from ISO format to ANSI format.. can I do this wihout having to recreate all my views and annotations?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,473 PRO
    Have you tried selecting a new template for the sheet?
