Offset tool error in sketch mode.
LKRENZLER
Member Posts: 30 ✭✭
The offset tool in sketch mode seems to have an agrivating snag. It defaults to 0.25in but if any radius in your sketch is the same or more the feature is lost even if you really only want an offset of 0.125 as an example. Is there any way to get around this? It doesn't remember your last offset value (which it should). I don't know if any place to set a default value. Any ideas? This image also shows another pet peeve in that dimension numbers like the radius and offset in this case are always dropped over other entities making them hard to read.
When the offset is between the pivot point and the arc at a corner, then that offset will produce an arc.
If the offset is not between the pivot point and the arc, then the best the program could do is generate a square corner
If you want a round corner on an offset that is not between the pivot point and the arc, then you can use the sketch fillet to put a radius on that offset. It just won’t be parallel with the outer arc
In the picture below, the offset is not between the yellow pivot point and the yellow arc. The two dashed construction lines are normal (perpendicular so to speak) to the inner arc. Notice that the lengths of the two construction lines are different, which indicates that the inner arc is not parallel to the outer arc
If you are looking for a number of different fillet sizes in one sketch, then deselect the fillet tool and then re-select it when you want to make a different size from the previous one
Sounds to me like you’re looking for different size fillets
If that’s the case, you can key in different size fillets. You just need to deselect the tool after making one fillet, and then reselect the tool before making another fillet of different size
