How do I delete a sketch or a sketch point in FS?
MichaelPascoe
Member Posts: 2,688 PRO
I created a sketch with a point, then used the point in opLoft. I no longer need the point, but it is visible in the studio.
Is there a way to delete the sketch or perhaps create an invisible point that can be lofted to?
NeilCooke
Moderator, Onshape Employees Posts: 5,933
If the sketch was created in FeatureScript then you can delete the sketch but not an individual point using opDeleteBodies and qCreatedBy(id + “sketchname”)Senior Director, Technical Services, EMEA1
