Export Folders Needed
AuroraRonAuroraRon Member Posts: 137 PRO
It would really be helpful if we could export a whole folder in Onshape rather than just one file at a time.
It just takes far too long to do one file at a time.
Not everyone uses Onshape (but they should) and it's very hard to make sure they have current versions so I like to dump it on to a USB drive but have to spend too much time doing this.
    It would be handy.  Are you exporting drawings (pdf's) or the 3d files
  • AuroraRonAuroraRon Member Posts: 137 PRO
    Basically anything we create out of an assembly or part.   A PDF, DXF Flat, images and notes.
    Find it easier to export to a USB drive and hand it over to someone than have them try and figure out how to do it.  It is also for a backup that I know may not be needed here but its practice to do so anyway.
  • Lindsay_EarlyLindsay_Early Member, Onshape Employees, Developers Posts: 24
    If you go to help > contact support while logged into Onshape you can file a ticket with the suggestion so it can be officially documented.
