For loop, sum up to the current loop?
MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
edited September 2020 in FeatureScript
Is there a way to sum up to the current loop? The loop calculates an angle, I need the n'th loop to add up all of the previous loops angles.
for (var i = 1; i < nSegments; i += 1)
            var = sumOfPreviousSegmentAngles =
            var segmentAngle = atan(d / sqrt(i))/degree;
  • MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
    Thank you, I will try this.
    And didn't noticed it from the beginig, but since you dividing the result of arctan by degree you don't need degree units for sumOfPrevousSegmentAngles, so just
    var sumOfPrevousSegmentAngles = 0;
    ^ Also though it is usually better to keep the units attached to unit-ed values.  This ensures proper use of those values down the line and helps prevent mistakes.
