For loop, sum up to the current loop?
MichaelPascoe
Member Posts: 2,827 PRO
Is there a way to sum up to the current loop? The loop calculates an angle, I need the n'th loop to add up all of the previous loops angles.
for (var i = 1; i < nSegments; i += 1)
var = sumOfPreviousSegmentAngles =
var segmentAngle = atan(d / sqrt(i))/degree;
}RENDERCAD
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
Yes, you just need to decleare sum variable outside of the loop.var sumOfPreviousSegmentAngles = 0*degree;
for (var i = 1; i < nSegments; i += 1) { var segmentAngle = atan(d / sqrt(i))/degree;
sumOfPreviousSegmentAngles+=segmentAngle; }
5
RENDERCAD
