Creating a circular pattern of equal length lines in a sketch
bit_stone
Member Posts: 5 ✭
Hello there,
I am trying to create a sketch that looks like this:
Is there a way to create those 1000mm lines without placing them all manually?
I've tried using a circular pattern.
But the radius could be pretty big (like 35000mm) and the length of the lines is usually just about 400-500mm.
Using a circular pattern I would have to convert the distance to a very small angle and that sometimes results in inaccuracies.
Any ideas? Am I missing something?
Not sure what you mean by inaccuracies? How many 1m lines should there be? You could make a sketch pattern first of the number of lines you need then add the 1m dimension.What is this for? Maybe there is a better way.Senior Director, Technical Services, EMEA0
@bit_stone
You can create a circular pattern in the sketch, then delete the angle dimension and set the ends of the lines coincident.0 -
Hello,
I*ve been testing around for a little bit.
I am currently thinking about using OnShape for our business.
This is what I am trying to accomplish:
https://cad.onshape.com/documents/4665afd6bee0c73aa715e0a0/w/8c31376fe87a14363bc91dec/e/89c48e6c954dcbf0c9e428b2
Looks like it would be best to just add the lines manually.
Is there a better way to get this result without converting the lines to equivalent angles and using a circular pattern?0 -
@bit_stone something like this if I understand what you are trying to do correctly?
https://cad.onshape.com/documents/4765de7101c0acfee316e098/w/5addae968925b8ce8149c76b/e/27406509178d4707c4fe1977
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
Partly, yes.alnis_smidchens said:@bit_stone something like this if I understand what you are trying to do correctly?
But they need to be equally distanced on every row.
But I think it would be best for me to have a look at creating a FeatureScript for this
