How can I make a sketch wrap around a non-cylindrical surface?
I'm trying to make a detail on a helmet that wraps around the side of the helmet (similar to the vertical one in the picture), but I don't know how to do that and the wrap tool doesn't work because its not a cylindrical surface. How can I do this?
Unfortunately, there isn't much you can do with a projected curve once it's made. If it's closed, you can turn it into a surface. But you can't use it to extrude or split.
Lead Mechanical Engineer @ Healing Innovations
https://cad.onshape.com/documents/5fc46cef3951103b7a887067/w/33594d1d5cc48bd72eafc7f4/e/72453ecc2538b0bb86d65d87
