What is the best way to put holes, for fastening, in two parts from different part studios?
William_Schlund
Member, Channel partner Posts: 9 ✭✭
I have two parts assembled together from different part studios.
I want to put holes in both parts, that line up, so they may be fastened together.
What is the best way of doing that?
The second part was imported from a 3rd party CAD system so it got put in its own part studio.
https://cad.onshape.com/documents/7b4b1626dfe8c5ea7f6e49ce/w/e2289df862ca22f90f5a06da/e/c301629c8a9e093d067a4ac5
In this example, edit the Derived 1 feature to see the source. I used Boolean 1 to create a hole simultaneously in both blocks.
www.virtualmold.com
