Why does one side of the loft go vertical but the other goes diagonal?
I'm trying to connect a surface and offset surface with the loft tool, but the way both sides connect is not identical as I would want them to be. Why is this happening and how do I fix it?
Here's a link to the document: https://cad.onshape.com/documents/337ad699769db0f7ebbdfe4d/w/11416bda5d90d35d062d6514/e/69da68dac6256402d28fd492
