opExtrude UP_TO_FACE Issue
aaron_skidmore
Member Posts: 34 ✭✭
Hi there, when I opExtrude as per below if the regionToExtrude is within the boundaries of the bottomface, it works ok, but if the regionToExtrude is outside the boundaries of the bottomface it doesnt work, is this expected behavior?
opExtrude(context, id + "extrude1",
{ "entities" : regionToExtrude,
"direction" : zDirection *-1,
"endBound" : BoundingType.UP_TO_FACE,
"endBoundEntity" : qNthElement(bottomface, 0),
"operationType" : NewBodyOperationType.NEW,
"defaultScope" : true
UP_TO_FACE is a deprecated option. Please use UP_TO_SURFACE instead, which will expand the given face to its infinite boundary, if possible. See: https://cad.onshape.com/FsDoc/library.html#BoundingType
Internally, when selecting the "Up to face" option in the extrude feature, you are actually selecting UP_TO_SURFACE enum. See the implementation here:
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/0ef5bec0909d4235a5ca1ebb
I am now struggling to find a way to get a solid bodies that intersection another solid body, via evCollision ? Or qIntersection ?
qIntersection is not a geometric concept. It is just a simple set intersection. For example if I had two queries that represented:
[face1, face3, face5] and [face1, face2, face3]
The intersection of those two queries is [face1, face3]
Similar to qUnion and qSubtraction, it is just a way to combine, find the overlap, or remove queries from each other. See: https://cad.onshape.com/FsDoc/library.html#qIntersection-array
evCollision ( https://cad.onshape.com/FsDoc/library.html#evCollision-Context-map ) will happily collide with multiple bodies at once.
const collisions = evCollision(context, { "tools" : bodyA, "targets" : qEverything(EntityType.BODY) -> qBodyType(BodyType.SOLID) }); var targetBodyArray = []; for (var collision in collisions) { targetBodyArray = append(targetBodyArray, collision.targetBody) } // To de-duplicate, since collisions are per-face/edge const allTargetBodies = qUnion(targetBodyArray); debug(context, allTargetBodies);
