Pattern point to point help?
MichaelPascoe
Member Posts: 2,681 PRO
I'm trying to transform copy a selected face from one point, to another so that I can use it in multiple places. I keep getting stuck on opPattern or transform. Can someone help me understand how to do this?
Here is what I have so far. The opPattern is where it breaks.
var count = -1;
for (var edges in pathFaces)
count = count + 1;
var point0 = vector(midpointBottomPath0, selectedPathPlane.x, selectedPathPlane.normal);
var point = vector(midpointBottomPath, selectedPathPlane.x, selectedPathPlane.normal);
const transform = transform(point0[0] - point[0]);
opPattern(context, id + "pattern" + count, {
"entities" : definition.profile,
"transforms" : transform,
"instanceNames" : count
}Learn more about the Gospel of Christ ( Here )
Jacob_Corder
Member Posts: 139 PRO
@MichaelPascoe
Point0 and point are vectors, however, x is valueWithUnits, y is a unitless vector and so is z.
I think you are trying to make point0 and point planes.
line 39
var point0 = plane(midpointBottomPath0, selectedPathPlane.x , selectedPathPlane.normal);
line 67
var point = plane(midpointBottomPath, selectedPathPlane.x , selectedPathPlane.normal);
line 79
const transform = transform(point0,point);
vector(x,y,z) does not have checks in it for anything other than size > 0 and it is an array.
this will create a plane to plane transform which is likely what you want5
https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/8b106df01719710c977fd8c3/e/7052b96c07018ad97bbadbf9?jumpToIndex=487
Onshape, Inc.
line 39
line 67
line 79
Thank you @Jacob_Corder, @NeilCooke, & @TimRice
I will give this a try.
