opEnclose Missing from FeatureScript Documentation
Alex_Kempen
Member Posts: 258 EDU
Hello,
as the title states, it appears that the documentation for opEnclose is missing from the FeatureScript Standard Library Documentation. The only mention of opEnclose in the documentation itself is in the Enclose feature, which curiously includes a link to opEnclose; however, the link appears to be broken, and simply takes you to the top of the documentation.
https://cad.onshape.com/FsDoc/library.html#enclose-Context-Id-map
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Both of these are marked as internal which usually means that their implementation may change.
Senior Director, Technical Services, EMEA6
