transparent parts not transparent in assembly
I have an assembly that has a transparent part. When I create the assembly the part seems to lose the transparency in the assembly. Is there a way to keep it transparent in the assembly?
Appreciate any tips on this.
Thanks!
NeilCooke Moderator, Onshape Employees Posts: 5,895
The assembly will show the parts as they are defined in the Part Studio. Did you set the appearance of the part (right-click edit appearance) or just change the shading settings? The former is the correct method.Senior Director, Technical Services, EMEA6
I edited the appearance at the part level per your comment and it is now correct.
Thanks!
