HowTo? Efficiently search / skim Public designs selected by a keyword?
KGHN
Member Posts: 4 ✭
I'm just starting with Onshape. I want to design a special joystick. When I search Public for "joystick" (or "potentiometer") to see if anyone has already done a design, or a similar design, the list is very long and scrolling is erratic. What's the preferred way to quickly skim available designs?
Not sure what you mean by a 'very long' list - I am only seeing about 30 of each. And scrolling with the elevator bar should work fine.
To evaluate the designs besides seeing the thumbnail previews, you can see which docs have more Likes, Links, & Copies as indication of what others have found useful.
For example the Potentiometer by 'marco onthernet has 45 Links & 4 copies. It has a dozen or so electronic components.
You could also browse the Internet for supply houses that offer CAD models of their products.
Good luck!
To quickly skim available designs in Onshape, the user can try using filters to narrow down the search results. They can filter by file type, author, date range, and other criteria to find designs that are most relevant to their needs. Additionally, using specific keywords or tags in the search bar can help to refine the search results and make it easier to find designs related to their project, such as "joystick" or "potentiometer."
To efficiently search/skim public designs in Onshape selected by a keyword, try the following:
Use Filters: Use filters to narrow down the search results based on file type, author, date range, and other criteria.
Specific Keywords: Use specific keywords or tags in the search bar to refine the search results and find designs related to your project.
Browse Top Designs: Browse the "Top Designs" section on the search page to quickly view the most popular designs related to your search keyword.
View Thumbnails: View the search results in "Thumbnails" view to quickly scan the designs and get a visual overview of what's available.
Collaborate: Connect with other users on the platform and collaborate on designs to create a customized joystick design that meets your specific needs.
More on, Use specific keywords, explore categories, preview thumbnails, etc.
Thank you.
