Feature Script availability
I was interested in a Feature Script (Project Body FS) used in a response in the post: https://forum.onshape.com/discussion/14643/help-needed-to-create-a-frame-around-a-part#latest.
I just wanted to take a look at it to determine if I might like to use it. I made a copy of the document linked by romeograham.
Within the document, I attempted to use Add Custom Feature to access it but it was not listed.
I also checked here: https://www.onshape.com/features/custom-features
but didn't find it there. Why was I not successful?
Two good options:
1) If you don't care about editing the Part Studios, no need to make a copy. You can add the custom features from a public document to your toolbar right there:
2) After you've copied, in a Part Studio, press the "+ custom features" button in your toolbar. Clicking features from the current document (or other documents) will those custom features to your toolbar. Note that this dialog has separate tabs for "Current document" and "Other documents" – It's possible you were searching in other documents tab for features from the current doc
Here's the direct link to thr Project Bodies FS: https://cad.onshape.com/documents/201b33ee5450cefbca3b34b8/v/9028ee782ed5ec471178bca1/e/03f0c71d4856a8408c7766a0
www.virtualmold.com
