Lesson Idea 10: Halloween Pumpkin Design
Curriculum Idea: Students will create a pumpkin and carving design
Topic area: Design
Description: Assign students to find/sketch their own design to carve into a pumpkin. Students can also be tasked with modeling their pumpkin in Onshape. Their are number of ways to make a pumpkin in Onshape with varying degrees of difficulty (simple revolve, circular patterning, surface modeling, etc). They can then take a photo of their carving hand sketch with a phone/other device and import it into Onshape. Then, trace this photo in a sketch so that the sketch can be used to extrude remove from their pumpkin model.
Learning Objectives: After completing this project, students should be able to:
- Use images as a start for a sketch
- See how the same object can be modeled different ways
- Develop conceptual designs while thinking about if it could actually be manufactured (carved)
Models:
Link to Model (Has three examples of ways to model a pumpkin)
Other resources:
Pumpkin Ideas: https://www.insider.com/easy-pumpkin-carving-ideas-2017-10#try-a-simple-ghost-design-11
https://rit.onshape.com/documents/defb1192a77f08678d7a065f/w/d64b568e83254a81cbef8285/e/c11fc2ed1977761df18d6866
*Disclaimer, we are not running a competition for pumpkin models in 2021, the rules and Amazon gift card offer above are not active and valid for October 2021. We encourage you and your students to share your work on social media using #MyOnshape for a chance to be reposted on our platforms.
