Partially Transparent
peter_wottapeter_wotta Member Posts: 3 EDU
I am finished a part but yesterday, before I completely finished it, I used my phone to show my friend my drawing. I guess I hit something and now it is partially transparent.  It still shows the color and everything but I can see all the lines and edges from the backside of the shape. It also shows whenever I look at it at any angle besides straight on. How to I make it so that it is not partially transparent. I tried looking in the rmb menu and the transparency menu thing but I can't find how to do it. Any suggestions?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
    It is partially transparent when the sketch is not active so that you can see the model through it.
  • alnisalnis Member, Developers Posts: 452 EDU
    Select shaded after tapping the view cube on mobile
    Or if it's on desktop in the right side view menu
  • peter_wottapeter_wotta Member Posts: 3 EDU
    Thanks
